Author Topic: Fuel Lift pump or main pump  (Read 1356 times)
Offline 98mpart
« on: 21 April 2008, 17:53 »
My Mk2 started making a buzzing noise, coming from the rear O/S of car. Have worked out it is prob the fuel pumps but which one as the lift pump is £25 and the main pump is £100. The car starts and runs OK sometimes, but has cut-out, feels restricted when booting it. Any Ideas which one guys and how easy r they to replace and How?
cheers
Mart
Offline Khare
  • The bear that khares
Re: Fuel Lift pump or main pump
« Reply #1 on: 21 April 2008, 22:59 »
my opinion is buy the lift pump which is £25, if the problem isnt sorted then its the main pump.
Offline Simeon
« Reply #2 on: 22 April 2008, 01:30 »
Agreed, this is far more likely to fail and is relatively easy to change - I did mine at the road side.
Offline Simon8v91
« Reply #3 on: 22 April 2008, 13:39 »
If the buzzing stops when you have a full tank of fuel its most likley the lift pump thats at fault.  :smiley:
« Reply #4 on: 22 April 2008, 13:50 »
pull the plug from the main pump, turn the key 1 click.  If you hear the loud buzzing still or hear nothing at all, its lifty pump!
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #5 on: 22 April 2008, 13:56 »
 :embarassed: sorry if this is hijacking the thread but im working on a mates mk2 and this thread caught my eye  :smiley:
I havent checked power to the lift pump yet but the main pump is only getting 2volts? i thought the lift pump might be knackered and draining all the power, is that likely  :smiley:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
« Reply #6 on: 22 April 2008, 13:59 »
cheers
Mart
If you can hear it more outside the car id say its the main pump, but if its buzzing it should be working, maybe a bit blocked. are you sure theres fuel in it? if in doubt bung a fivers worth in, it cant hurt  :smiley:
my dub project:-
Offline Skiing
« Reply #7 on: 22 April 2008, 14:12 »
Mind did this, used to conk out occasionally (buzzing would get louder and then it would die) - replaced the in tank lifter and it was completed fixed.
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
« Reply #8 on: 22 April 2008, 15:29 »
if it only getting 2v id suspect its the realy or wiring that kaput.  if you suspect lift pump is draining too much power, unplug it!
