Author Topic: GTI Mk4 oil problem.  (Read 3735 times)
Offline PM1967
« on: 21 April 2008, 09:58 »
I seem to be going through a lot of oil, got serviced a few months back and had to put more in twice. No signs of the oil leaking or the car burning oil. Any ideas? Also got an O2 sensor which I had replaced but it keeps switching the car to lean mode, I can clear the fault with a hand held diagnostic checker but it happens more regularly as the oil level goes down.
Offline Rhyso
Re: GTI Mk4 oil problem.
« Reply #1 on: 21 April 2008, 10:19 »
could be a number of things - coilpacks, lambda sensors
what fault code does the scanner bring up??
what sort of journies are you doing?? if its short start and stop then it will use more oil than usual
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 21 April 2008, 10:21 »
Would this be the 2.0 gti by any chance? They're known to drink oil almost as fast as they do petrol. O2 sensor usually fixes it, can't think why yours hasn't.. unless you over-filled the oil slightly at some point and killed your CAT.
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 21 April 2008, 10:58 »
My 2.0 MK4 drinks more oil than I do beer :(
Offline PM1967
« Reply #4 on: 21 April 2008, 11:58 »
Drive about 50 miles a day. It is the 2.0 GTI. I had the lambda sensor changed but doesnt seemed to have fixed it. Theres a bit of imulsification on the oil cap but no obvious signs of the Gasket being away, car doesnt over heat, no excess smoke, no oil in the water etc...
Offline peanut1981
« Reply #5 on: 26 October 2011, 13:54 »
Same problem here. I think it's just a thirsty b******  :sad:
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 26 October 2011, 14:13 »
Offline Khare
  • The bear that khares
« Reply #7 on: 26 October 2011, 14:14 »
Was gonna say...Found it strange when I read this
 :grin:
Offline peanut1981
« Reply #8 on: 26 October 2011, 14:17 »
Offline AlanD
  • MK5 2.0T 16v
« Reply #9 on: 26 October 2011, 15:07 »
 :grin:
Ahhhh those were the days aye :D
