Author Topic: Wheel cleaner?  (Read 3961 times)
Offline block
Re: Wheel cleaner?
« Reply #20 on: 21 April 2008, 13:02 »
Another tardis user here, its excellent for removing tar from not only your wheels but also your paintwork, it basically just wipes off. Just remember to re-wax afterwards.
 It may seem like a big tub but you'll soon go through it.
GTI Mk7 5dr, PP, Nav, Red.
Offline acwats
  • Boys need Toys
Re: Wheel cleaner?
« Reply #21 on: 22 April 2008, 19:17 »
Cheers Shaun, thought as much but you never know if someone has a trick up there sleeve or a new wonder product  :huh:
you don't need to go for a long drive, a quick reverse and forwards with the brakes held on soon works - even easier if you've got DSG (or a choke!)
Mid Life crisis history:2000 Yamaha Fazer 600
2002 Westfield 1800 (built it too!)
1987 Porsche 911 3.2 Carrera Targa SE
MkV GTI DSG
TeddyKGB
Re: Wheel cleaner?
« Reply #22 on: 23 April 2008, 21:40 »
The Hots Rims to clean the brake dust off
Is this safe to use on 18" laquered monzas? I have ordered some but it smells quite harsh (like.. acidy) and not sure if I should use it or not :undecided:
Offline SteveS
  • GTI ED30
Re: Wheel cleaner?
« Reply #23 on: 23 April 2008, 21:43 »
well peolpe on DW are using it on everything.... if its ok on paint i wouldnt see why not... try it on the back of the wheel first?
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline 182_blue
Re: Wheel cleaner?
« Reply #24 on: 23 April 2008, 22:29 »
he is talking hot rims though not tardis, i would be cautious with it, make sure its all off, and possibly water it down, the monzas are lacquered so will take a bit of abuse, but if theres cracks, scratches etc then the hot rims may sneak in
