Author Topic: HALL SENDER ON A MK2 FIT A MK3??  (Read 909 times)
Offline AndC
« on: 19 April 2008, 18:56 »
Hi guys,
Sorry to invade your forum with my MK3 concerns but I have a problem and wonder if any of you could help?...
Does anyone know if the hall sender on a MK2 1.8 GTi would fit my MK3 2.0 GTi?
They look the same but I suspect are probably different, I have posted on here quite a bit about the problems I'm having but to summarize:
The car intermittently cuts out and the oil light flashes, unlike some other people on here what I do with the revs makes no difference and it usually does it over 2000rpm, alot of the posts I've read say that if I can keep it over 2000rpm then I should be ok, this isn't the case with me in fact almost the opposite, it usually happens after I've been gunning it a bit the other day it did it as I was overtaking!..
I have had it on a diagnostics machine but it doesn't come up with any error codes.
I have replaced the crank sensor.
I have replaced the ECU power relay (No.30)
This is all beginning to take it's toll on my wallet and my Mrs is insisting that I should spend my money on feeding our 3 kids rather than chucking it all at the car!, fair enough I suppose?
My mate has a MK2 that he isn't going to be using for a few months so suggested if they are the same I should put that on to eliminate it?
I've got to get this sorted as I have about a 100 mile round trip to work so if it keeps doing this it's going to have to go to Golf heaven!!!
Has anyone got any ideas??
Any other suggestions what might be causing the problem?
Thanks
Offline AndC
Re: HALL SENDER ON A MK2 FIT A MK3??
« Reply #1 on: 20 April 2008, 12:18 »
No one have any ideas???
« Reply #2 on: 22 April 2008, 14:10 »
I don't know if the hall sender will fit, but the entire dizzy definitly does not in case thats what you mean!
