Author Topic: Loose are rest  (Read 1063 times)
Offline keyser
  • They're only the band the beatles could've been.
Loose are rest
« on: 19 April 2008, 14:50 »
The slidey bit (think thats a technical term :smiley:) on my arm rest is quiet loose to the point that it slides forward when my elbow is on it and i brake.  Is there any way i can tighten it
MK5 GTI, manual, silver, dirty pipes.
Offline No Golf Clubs at all
Re: Loose are rest
« Reply #1 on: 20 April 2008, 07:13 »
Not sure if it actually tightens anything, but if you (gently) pull off the cover on the underside, there are 4 screws that you undo to take it apart...you will need an allen key to remove or tighten these.
If you are taking apart be careful...it can be a little tricky to get back together. The cover easily snaps back on again.
However if your car is under warranty I would take it to the local stealer if you can afford the time.
« Last Edit: 20 April 2008, 07:20 by No Golf Clubs at all »
Let the fun begin........Red Gti, full colour coding, DSG, Xenons, Winter pack, Lux pack, Highline, Sat Nav, Sunroof, Leather, Milltek, ABT rear valance, Goodyear F1 Asymmetrics....pescaras :-)
