Author Topic: Mk3 8v CUTTING OUT please help!  (Read 968 times)
Offline KingPin
« on: 17 April 2008, 12:16 »
Hey Guys
When the engine gets to about 70degrees it dies just cuts out and wont start again unless jumped or Cold :( Not applicable if im going over 50 it just kind of lurches and carries on. Fine when cold and fine when hot??
Had this problem for a while ive cleaned out the throttle because the low revs were causing it to die only to find that wasnt the only problem so I changed the Rotor Arm and Dissi Cap as rotor arm was a bit frayed. Now ive ran out of ideas.
Thanks Dan
“Learn from yesterday, live for today, hope for tomorrow.”
- Albert Einstein
Offline boneybradley
  • Back in a Mk3...
Re: Mk3 8v CUTTING OUT please help!
« Reply #1 on: 17 April 2008, 12:28 »
ecu or fuel pump relay...or temp sensor are most common causes
have a look in the mk3 maintanence section for a thread about these issues
Offline Phil_Gti-16v
« Reply #2 on: 17 April 2008, 16:36 »
Maybe a coolant temp sensor fault?
