Author Topic: HEAD GASKET GONE!  (Read 2841 times)
Offline RandomJord
HEAD GASKET GONE!
« on: 18 April 2004, 17:18 »
f**k sh!t BLAST ARSE TEETH WINKER!
head gaskets gone, im annoyed, anyone know how much this costs to put right? or shall i just go ahead an do an engine transplant for a turbo lump? an anyone know the cost of such a transplant an who can do em?
« Last Edit: 18 April 2004, 17:18 by RandomJord »
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
Blue MK2
Re:HEAD GASKET GONE!
« Reply #1 on: 18 April 2004, 17:57 »
more likely to blow something later on with a turbo lump :P
head gasket, i was quoted ?250-?300 for my digifant mk2 gti
Offline RandomJord
« Reply #2 on: 18 April 2004, 18:31 »
oh crap. thats quite a bit! is it worth doing or is this a sign of problems to come? or is it a sign to change the engine!
Veedubgt18v
« Reply #3 on: 18 April 2004, 18:37 »
yeah its worth doing its just a rubber/cork gasket to seal two metal faces. if you are woried about it get an uprated one
Offline RandomJord
« Reply #4 on: 18 April 2004, 20:02 »
Yeah mite aswell, what else can i uprate at the same time to get a better bhp?
marcus123
« Reply #5 on: 19 April 2004, 08:58 »
sorry to hear bout your head gasket mate :(
what were the tell tale signs before it went?
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #6 on: 19 April 2004, 09:09 »
Head gasket is usually shown in various ways from loss of coolant for no apparent reason - milky residue in your oil - oil in your expansion tank - running on 2 or 3 cylinders etc. Can be just one or a mix of all of them.
Just for you guys who aren't too sure, it's no big deal that a head gasket goes, and don't worry about it causing more problems later providing you get a pucker job.
The main thing people scrimp on is having the face of the head checked to see if it's still 'true' and then decked/skimmed where necessary. If you don't due to the head being alloy and the block Iron, it's possible for the head to warp and effectively twist when torqued back up. This will be a tiny ammount, but if unchecked when you bolt her back up you get problems with over heating etc and more importantly you run the risk of the cam seizing where it's bent!
Do get your head skimmed will cost about ?25, so if you're planning on keeping the car then insist it's done, or atleast check!
« Last Edit: 19 April 2004, 09:12 by davidhawkins_78 »
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
« Reply #7 on: 19 April 2004, 10:38 »
The upside to having your gasket go is your pistons get steam cleaned for free ;)
« Last Edit: 20 April 2004, 11:10 by rubjonny »
