Author Topic: one last q' after transplant  (Read 703 times)
Offline paultownsend
« on: 16 April 2008, 10:12 »
converted my tired 91'8v golf into spec below and have just covered 1000 breakdown free miles! (a few leaks though!)
agg bottom end (0% visable wear on bores, honing marks visable)
flowed tb
matched inlet
newman 268
ported head 40/35 valves
matched exhaust manfild
milltek exhaust
lightened balanced fly (1/4 weight reduction)
untampered afm
always ran on v-power
al the work was carried out by 2 well known welsh chaps, and im very very pleased with the visable results.
the cars been set up with the mormal guide, all new vw hoses used, and all new ignition consumables, gasketts and injector seals.
the problem is, the usual idle. it will rev hard up to the redline, so any myths of 2.0 mk2's not being able to rev properly is poop. it also gets there with a noticeable kick @4k.  but when it comes to rest, it always dips to the below set 950rpm idle rest, then will shoot back up again. its just a pain when driving in traffic. its also jerky on/off the accelerator pedel. iv fiddled around with the cable tension but just cant cure it.
i had my 1.8 digi running so smooth, so any ideas? maybe adverse affect of the lightened fly?
Paul
Offline Organisys
  • Old and Slow...
Re: one last q' after transplant
« Reply #1 on: 16 April 2008, 13:41 »
Still running Digifant Management I take it, if so check closed throttle switch and it's wiring on the underside of the throttle body.
Also check for the usual vacuum leaks.
 :smiley:
« Reply #2 on: 16 April 2008, 16:24 »
all done im afraid. perhaps an effect of the lightened flywheel and the isv trying to compensate?
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #3 on: 16 April 2008, 18:05 »
nah i shouldnt think the flywheel will make a difference, this is exactly what my car used to do and i found that it was the co2 and idle levels that needed adjusting. did you use rubjohns tuning guide yeh?
