Author Topic: wtf help  (Read 2311 times)
Offline dubslug
wtf help
« on: 17 April 2004, 22:58 »
guys i need some help over the last few weeks ive had this problem with me motor (mk2 1.6 driva)..
when its warm its idles at 1000rpm, then i go for a drive all is fine but when i stop at lights revs drop down to 250 rpm thenback to 1000rpm, while sat at the lights it will continue to do this unless i accelerate a bit/ why??
p.s its got a new battey, ok looking bushes on alternator(tried 2 now)new plugs leads cap and dizzie, any help appreciated cheers
rik
1992 pearl grey 8v
golfvr6
Re:wtf help
« Reply #1 on: 17 April 2004, 23:21 »
Check for vacuum leaks around the carb.
Offline dubslug
Re:wtf help
« Reply #2 on: 17 April 2004, 23:25 »
done that too, cant find any checked all the hoses on it too, its driving me mad
1992 pearl grey 8v
vwsystems
Re:wtf help
« Reply #3 on: 18 April 2004, 06:56 »
worth giving the carb a clean out with carb cleaner......
if this doesnt cure the problem it will sure as hell help to make it run better........
Offline dubslug
Re:wtf help
« Reply #4 on: 18 April 2004, 11:23 »
thanks for the idea vw but ive done that, its really really bad when i have the lights on
1992 pearl grey 8v
Offline davidhawkins_78
  • Valver Bad Boy
Re:wtf help
« Reply #5 on: 20 April 2004, 09:51 »
I've not idea how similar a driver is to a GTI, I'm guessing you'll not have any of the sensors etc as it's a carb engine ....
best thing to do next is get a service kit for your carb - remove it / clean it and replace all the consumables just so you can rule out any vacuum leaks. The kit will only cost ?20 or so ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Veedubgt18v
Re:wtf help
« Reply #6 on: 20 April 2004, 10:26 »
is it the peirburg carb? if so just ditch it for a webber, if its already a webber then service it and get it setup properly by a garage
