Author Topic: Clutch Cable Fitting  (Read 1827 times)
Offline Khare
  • The bear that khares
Re: Clutch Cable Fitting
« Reply #10 on: 20 April 2008, 09:42 »
at the other end were the cable is connected theres a adjuster isnt there?
Offline Martz
« Reply #11 on: 20 April 2008, 11:02 »
I could not see anything but will give it another go today. It was working for the 2 miles I drove then stuck? Nursed the old girl home, and very confused with it all. I am not a mechanic but will try what I can.
Will let you all know how I get on.
Martz :cool:
Offline Martz
« Reply #12 on: 20 April 2008, 15:05 »
Ok, so I got the Haynes manual out and went from there. The cable was fitted as mentioned and as far as I am aware, correctly. The only thing I had wrong was the adjuster straps, I did not release it. I done this and followed the process of pressing the clutch and so forth but still the same. The pedal is not releasing back once pressed??????
I noticed on th ediagram that there should be a weight on the clutch lever arm in the engine bay. This was missing when I first had a look so I had no idea.
Old cars are starting to pi5s me off!
Offline Uruk Hai
« Reply #13 on: 20 April 2008, 23:03 »
If you've got a new clutch cable and the pedals still not coming back up propperly I would be starting to wonder if the pressure plate is giving up ?
Offline Martz
« Reply #14 on: 20 April 2008, 23:13 »
I spoke to my mate and went through everything I have done. He did say that as it appears to not be returning it could be that the fork end is not engaging and something about the pressure plate. Maybe a new clutch will sort it out?
