Author Topic: Fuel Accumulator  (Read 2914 times)
StephenEggo
Fuel Accumulator
« on: 17 April 2004, 16:04 »
I have a 1990 Mk2 GTI 16V that is leaking fuel slightly. It looks to me that it is the fuel accumulator and the 2 fuel pipes that connect to it. The unit itself and the pipes are corroded so they both need replacing.
I went into my local vw dealer and was shocked to be told that the acccumulator costs ?150 and the pipes cost ?27 each. Does anyone out there no where I could find these parts cheaper?
Offline Dragon6
Re:Fuel Accumulator
« Reply #1 on: 17 April 2004, 16:10 »
had same bother myself my fuel reservoir was leaking from one of the 3 self tapper screws that hold the fuel pump in my accumulator was fairly well corroded along with pipes so I replaced the job lot wasn`t cheap but got a 15% discount from VW,at least I can 4get about that side of things,rang around the usual places euro car parts etc but they all said dealer only,
Offline richandhazel
Re:Fuel Accumulator
« Reply #2 on: 17 April 2004, 16:21 »
Might be able to find a good one at the scrappy :-\
If you do, I'd recommend reprotecting it all before fitting so it doesn't happen again.
Offline Dragon6
Re:Fuel Accumulator
« Reply #3 on: 17 April 2004, 16:26 »
yup certainly did a shed load of waxoil and those little rubber feet that hold the reservoir on are a pain in the ar5e as well to get off ,another vw rip off at ?3 odd for each foot.
Offline The Hoax
Re:Fuel Accumulator
« Reply #4 on: 17 April 2004, 17:35 »
Stevy,
I was stung by VAG similarly last year although I only needed the accummulator and one pipe.
I found out after I had ordered that German Swedish could do the accummulator for either ?60 or ?80 - I can't quite remember, but it certainly was only a fraction of VAG costs.
I hope that this helps
golfvr6
Re:Fuel Accumulator
« Reply #5 on: 20 April 2004, 18:24 »
I wouldn't get one from GSF as it will probably be leaking inside a week  ;)
