Author Topic: Car trouble!!!! Help needed!!!  (Read 1118 times)
Offline wookieGTI
« on: 14 April 2008, 02:05 »
I have a 8v digi and developed a problem about 2days ago.while accelerating my car kind or stutters and draws back a little,have checked the plugs and leads they seem ok.im no expert but to me it seems like some kind of fuel starvation would a fuel filter change sort this as it has never been changed since rolling out the factory.
Any help is much appreciated.
Offline Ant
Re: Car trouble!!!! Help needed!!!
« Reply #1 on: 14 April 2008, 08:47 »
Are you red lining when this happens? (I got a similar effect from a rev limiter)
Offline rombonie
« Reply #2 on: 14 April 2008, 09:03 »
Check the MAF connection
Offline wookieGTI
« Reply #3 on: 14 April 2008, 11:03 »
No not red lining when doin around 30-50mph,MAF connection???whats that where will i find that?
Offline rombonie
« Reply #4 on: 14 April 2008, 11:06 »
Its the air flow meter attached to the airbox, about a 2 inch wide connector, unplug and plug in several times, have a look to see if the contacts look clean.
Offline Horney
« Reply #5 on: 14 April 2008, 11:11 »
Digis are really really sensitive to bad leads. I would 100% recomend fitting a set from VW (not GSF or ECP), even if this doesn't sure your problem when you do fix it your car will be better than ever.
Nick
Offline wookieGTI
« Reply #6 on: 14 April 2008, 12:49 »
Been out and checked the MAF,gave a clean and plugged in several times,just been of a little drive and still got the problem.having had my mate drive who is a mechanic he seems to think its an igntion problem.maybe needs a treat to some new spark plugs and new leads??
Any more ideas are appreciated
Offline rombonie
« Reply #7 on: 14 April 2008, 12:55 »
when its idling can you hear or feel it missing slightly ...very occasional?
Offline wookieGTI
« Reply #8 on: 14 April 2008, 12:57 »
no its when driving,going through the revs accelerating through the gears then backing off and accelerating again is when you feel it missing slightly.
Offline rombonie
« Reply #9 on: 14 April 2008, 13:03 »
you sure its not missing on idle? this would suggest the leads.
Did this start after you filled up?
Is it a miss or a hesitation?
