Author Topic: oh dear... speedo drive dropped into gearbox...  (Read 1611 times)
Offline dabill
« on: 12 April 2008, 15:34 »
right, been working on the 20v, and the speedo drive, the cog bit on the end of the speedo cable has dropped into the gearbox...
whats the best way of retreiving this? im guessing its gonna be seriously fiddly!
noble tuned - and still not fast enough!
Offline Khare
  • The bear that khares
Re: oh dear... speedo drive dropped into gearbox...
« Reply #1 on: 12 April 2008, 16:18 »
maybe one of those extendable magnets, or extendable "claw"
Offline Conker
« Reply #2 on: 12 April 2008, 16:49 »
...the cog bit on the end of the speedo cable has dropped into the gearbox...
I bet that caused some four letter words...
Offline ben44
« Reply #3 on: 12 April 2008, 18:05 »
pretty sure its plastic!  :grin:
what gearbox is it mate?
My signiture sucks..........................
Offline Uruk Hai
« Reply #4 on: 12 April 2008, 18:15 »
I think some one on here has had that happen before and just leaving it didnt cause any probs !
P.S they should be plastic
Offline dabill
« Reply #5 on: 13 April 2008, 10:14 »
yeah its the 8v gearbox me thinks... but just wondered if there was a tried and tested method other than dismatleing the gearbox, for getting the bugger out. might drain the gear oil and see if i can see a little better...
which plug is it on the bottom of the gearbox for oil drain? the small 13mm bolt, or the huge fook off mazzive allen get nut under the diff?
Offline monzablue16v
« Reply #6 on: 13 April 2008, 12:22 »
That sucks! the second one is the one to undo. Not sure if it will help you get it out but those claws on a flexible rod are great for picking up nuts and such that I always drop. If you can see it you should be able to grab it.
Offline dabill
« Reply #7 on: 13 April 2008, 15:14 »
i cant see it yet... but i can feel it, think its slipped sideways and needs moving so its upright, then i'll just lift it out, cant do anything for a week or so now i dont think so just have to wait and see lol...
Offline Uruk Hai
« Reply #8 on: 13 April 2008, 16:53 »
It is the 17 mm allen nut, its the same size as the nut you have to remove to fill the box  :wink:
Offline Agreeable Slick
  • Unit
« Reply #9 on: 13 April 2008, 18:46 »
just let the gears crush it up, then drain and refill. Oh and this has been covered loads of times before, use the search function ta.
