Golf mk3
hardmonkeys
vr6 running hot
Topic: vr6 running hot (Read 1950 times)
bow
vr6 running hot
12 April 2008, 15:02 »
hi there i have a 94 vr6 which i think is running hot it runs at just over 110 before the fan cuts in then comes down to about 85 90 iv changed the rad fan switch and it made no change at all is this normal if not what can i do thanks scott
bow
Re: vr6 running hot
12 April 2008, 15:35 »
help it driving me mad
bow
Re: vr6 running hot
12 April 2008, 15:44 »
come on someone please
Mikester
Forum addict
Civic Type R
Re: vr6 running hot
12 April 2008, 16:45 »
Might need a new thermostat. When the car is warm how hot are each of the pipes coming form the rad, maybe the thermostat is stuck and needs replacing. or the radiator could be blocked.
Its either that or a temp sensor i would think.
bow
Re: vr6 running hot
12 April 2008, 17:02 »
they not to hot as you cant hold them not the rad ether i replaced it as i got the car with a front how do i check the reading on the dash is a true reading also what temp should it run at
Mikester
Forum addict
Civic Type R
Re: vr6 running hot
12 April 2008, 17:06 »
Depends, when im runnin at 70mph it sits way down, and through town at 30 stopping and starting it can get to almost mid way on the gauge. If it gets to warm the rad soon takes it down.
Im thinking thermostat
bow
Re: vr6 running hot
Reply #6 on:
12 April 2008, 17:42 »
just been playing with it and it seems the fan is only working on 1 speed and thats on slow also in about half an our im having a code reader 4 10 mins were dose it plug in
Mikester
Forum addict
Civic Type R
Re: vr6 running hot
Reply #7 on:
12 April 2008, 17:49 »
bow
Re: vr6 running hot
Reply #8 on:
12 April 2008, 18:18 »
just code read came up with 00513 which is engine speed sensor fault i can buy the code reader 4 £20 is that a good deal and ill replace themostat tomorrow
bow
Re: vr6 running hot
Reply #9 on:
12 April 2008, 21:36 »
can any 1 tell me how you check the rad cooling fan it only works on speed 1
Golf mk3
hardmonkeys
vr6 running hot
