Author Topic: Accelerator pedal problem?  (Read 8927 times)
« on: 12 April 2008, 14:19 »
A quick hello to all in the mk5 section  :smiley:, not new to VWs or mk5 Golfs for that matter as I had a modified 140 TDI before and a good few TDIs and GTIs etc before that, but have a question about my fairly recently acquired GTI. It's a 40,000 mile 54 plate early car in grey. Manual btw.
This is aimed at those who have slightly older and higher mileage cars really but it would also be useful for owners of newer GTIs to give me some feedback.
Not sure if my car has an issue with the accelerator pedal, it seems pretty slow to pick up unless the pedal is pushed in about an inch or so. Once past the first bit of deadish travel it's off and away.
I can remember test driving a few before I got my previous diseasel and don't remember the dead throttle pedal travel. My wife's Polo is fine, touch the pedal and off you go, my Diesel mk5 was fairly similar to the GTI but then again the 140 doesn't have quite the same low rev urge of the 130 and 150 1.9 units despite nominally the same torque figures in my experience.
I don't remember many of my 1.8Ts and 1.9PDs feeling so dead on throttle pedal application and there's no play in my GTIs pedal so the spring 'feels' okay. Certainly after driving a Polo GTI with it's razor sharp throttle response my 2.0 TFSI seems 'not quite right'.
If this is typical of GTIs then has anyone tried the Sprint-booster device?
TIA    :smiley:
Re: Accelerator pedal problem?
« Reply #1 on: 30 April 2008, 18:07 »
Ah well despite everyones reluctance to talk to me I thought I would reply to myself just in case anyone else has the same concerns.
Firstly I simply got the car re-mapped. The pedal now seems to do something in the first few mm of travel so that answers my question there - the mk5 Golf has dead travel built in. Having tried a Polo GTI which had razor sharp throttle responses I wrongly hoped the Golf was the same.
And to the last bit of post #1, I managed to find a forum member from another forum who is local to me with a Sprint Booster. It's great when you want a blast but not too easy to control in stop start traffic especially if you have a re-map. Undecided if I want one or not as at over £150 its not exactly cheap. :undecided:
Offline winrya
« Reply #2 on: 30 April 2008, 18:12 »
I'm not sure about everybody else but there isn't even a mm of dead travel in my pedal????  Can't comment on why the remap sorted it out??
Offline 182_blue
« Reply #3 on: 30 April 2008, 18:13 »
i dont appear to have any travel either, although a bottom hinged pedal did take a bit of getting used to
NewGolf
« Reply #4 on: 30 April 2008, 18:15 »
I dont have any travel at all before my engine speed increases, and never saw your first post Exonian, apologies  :smiley:
Offline SteveS
  • GTI ED30
« Reply #5 on: 30 April 2008, 18:16 »
im not sure really, iv have put it down the the turbo kicking in, which makes you think your havnt put your foot down untill it does... until that point its almost like not moving
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline 182_blue
« Reply #6 on: 30 April 2008, 18:20 »
is this a rev issue, as in you dont go very quick till you hit a certain rev range ?, i.e over 3k etc ?
« Reply #7 on: 30 April 2008, 18:23 »
Ah replies! I was beginning to think I smelled bad!!!
Thanks for the feedback. Maybe my Golf has other issues? Maybe the spring is getting a bit worn on the pedal?I'll have to invest in a fault code reader sometime I guess, save keep taking it to VW and it's out of warranty in a few months  :sad:
Thanks for the feedback anyway.  :smiley:
« Reply #8 on: 30 April 2008, 18:25 »
The car does seem a bit flat after several modified 1.8Ts and TDIs but revs cleanly. But the original post is more to do with the pedal itself (I think  :undecided:)
Offline 182_blue
« Reply #9 on: 30 April 2008, 18:45 »
pedals are quite cheap from what i remember
