Author Topic: Dump valve  (Read 3182 times)
Offline Richy1985
Dump valve
« on: 11 April 2008, 16:58 »
[ Has any 1 fiting a dump  valve on a tdi???
« Last Edit: 11 April 2008, 17:02 by Richy1985 »
Offline Rhyso
Re: Dump valve
« Reply #1 on: 11 April 2008, 18:16 »
not worth it mate tbh; couple of people have but there's not much you can do to improve the sound of a derv  :laugh: :laugh:
Offline Richy1985
Re: Dump valve
« Reply #2 on: 11 April 2008, 18:23 »
sum 1 told me they run like a bag of sh!t :undecided:
dont think iam goin bother
bye the way i have posted sum pics up of me car :smiley:
Offline Rhyso
Re: Dump valve
« Reply #3 on: 11 April 2008, 18:25 »
yeah seen them; had to edit the post slightly as you had the image tags [img] in the wrong place
Offline Richy1985
Re: Dump valve
« Reply #4 on: 11 April 2008, 18:28 »
wer have they gone nw!!!! :rolleyes:
thanks m8
Offline golflad
Re: Dump valve
« Reply #5 on: 29 April 2008, 17:29 »
i've put a dump valve on mine and it has made no difference to the running of it at all. mines the 150 and it sounds awesome but i fitted one to a 130 and it didn't sound as good and i can only assume it's to do with the intercooler and the way the dumpvalve mounts on the car. if you're gonna do it make sure you get a bailey dual piston valve as they sound better. best way to get them to work is with a micro switch mounted on the throttle pedal via a specially made bracket which i can get hold of and wiring it to an actuator which acts as a valve letting the dump valve dump when you let off the throttle. as you may know, diesels don't run their own vacuum system so you need to splice into the brake vacuum but don't be alarmed about that as it still maintains the pressure, it's just to hold the dump valve shut. i certainly wouldn't rule out putting one on.
Offline Richy1985
Re: Dump valve
« Reply #6 on: 06 May 2008, 12:01 »
nice 1 m8 not sure how 2 fit 1??
sum 1 did give me a price of 300 pounds, thats wot put me of  :huh:
Offline Cosworth Lee
Re: Dump valve
« Reply #7 on: 17 May 2008, 21:18 »
