Author Topic: help me  (Read 3748 times)
Offline ian007miles
help me
« on: 11 April 2008, 15:36 »
does any one no were i can get a set ot anti roll bar bracets from they are the ones that hold the anty roll bar to the top of the wish bone near the wheal ive tryed vw, gsf, euro car parts and all say that they have been discontiued so if any ony has a set lying aroung that they dont need ille buy them thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline grungeisdead
Offline ian007miles
Re: help me
« Reply #2 on: 11 April 2008, 20:34 »
no mate its the other ones that go at the top of the wish bone. the ones on ebay are the ones that is underneath thanx any way mate
Re: help me
« Reply #3 on: 11 April 2008, 21:06 »
can you find out what part it is on vagcat as im struggling to understand what bit you mean, there should be two 13mm captive nuts form the top holding the arb bracket that is below, then you have the two inner arb mounts which have a metal clamp that clips to the chassis again with another 13mm captive nut
heres a couple of pics if you can see the bit or circle it out
Offline ian007miles
Re: help me
« Reply #4 on: 11 April 2008, 23:07 »
hi mate its the one with the 2 nuts
Re: help me
« Reply #5 on: 12 April 2008, 00:49 »
hi ian,
i can take a pic of the underside of that bracket but i thought that was the one that was part of the wishbone repair kit. Is that bracket included in there for the rear wishbone mount?
Best bet is to ask on here
http://www.vwgolfmk1.org.uk/modules.php?name=Forums
in the wanted section, or pm crazyquiff, he should have plenty in spare
thanks
saf
Offline ian007miles
Re: help me
« Reply #6 on: 12 April 2008, 10:38 »
the other thing is wen i bought the car the anti roll bar was on top of the wish bone not under it and still is is there reason for this
Re: help me
« Reply #7 on: 12 April 2008, 21:50 »
id assume your arb was installed upside down, all the mk1s ive had have them mount under the wishbone
see this thread its top and choc full of pics
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=36688
Offline ian007miles
Re: help me
« Reply #8 on: 12 April 2008, 23:24 »
right now im confused, i read that link and if you look at the first page were hes taking the front end apart the anti roll bar starts off on the top of the wish bone and the on the 3rd page wen hes putting it all back to gether he puts the anti roll bar under the wish bone.and the othe thing i just looked in the haynes manuel and that shows a picture of the arb on top of the wish bone as well
Re: help me
« Reply #9 on: 12 April 2008, 23:39 »
 :huh: :huh: :huh:
i see what your on about now, thats stumped me aswell!
mines have always been mounted at the bottom, ill ask why his was mounted at the top in the thread and ill check my haynes as its sitting on top of my monitor lol
edit: yup haynes says it goes on top too!!! it'll be the same bracket either way chap as in that ebay auction, gsf also stock the wishbone repair kits, as above i just bought new wishbones and polybushes (i have a spare set of front wishbone polybushes 4 in total) if your interested while you've got it apart
« Last Edit: 12 April 2008, 23:43 by grungeisdead »
