Author Topic: power roar induction pipe  (Read 3572 times)
Offline Ben Lessani
Re: power roar induction pipe
« Reply #1 on: 11 April 2008, 18:47 »
No mandrel bend - no love   :undecided:
Offline Agreeable Slick
  • Unit
« Reply #2 on: 12 April 2008, 09:08 »
you probably could, but really, what's the point.
Offline dan23
« Reply #3 on: 12 April 2008, 12:18 »
just wanted to know really as i thought it would look quite good, and i hear they make a bot more noise
never mind tho
cheers for the help tho guys
Offline Ben Lessani
« Reply #4 on: 12 April 2008, 12:32 »
Your best bet is to measure up the dia's on the airbox exit and the throttle intake, then mail the seller and find out if they match. Even if they don't you can always get a little bit of Samco'esk hosing to get them to match up, but your cost will start to climb.
Offline cняis
« Reply #5 on: 12 April 2008, 12:44 »
get some alloy tubing with the right OD, you can buy it in various lengths with/without bends, just cut to size:
http://search.ebay.co.uk/search/search.dll?from=R40&_trksid=m37&satitle=alloy+induction
Offline dan23
« Reply #6 on: 12 April 2008, 13:01 »
good thinking my man, if only id thought of that, and the pipe doesnt need a breather hole either does it, and how would i measure the dia's on the throttle intake and airbox exit?
Offline cняis
« Reply #7 on: 12 April 2008, 13:40 »
well you will need to either cut up the existing rubber pipework by trimming 1.5 or 2 inches off each end to make joiners for the the new alloy pipework, or you can buy silicon joining rings (eg samco etc etc) to join the alloy pipe to the airbox exit and intake manifold. you will need 4 jubilee clips too (as you'd justaswell replace the o.e. ones)
what it basically means is the the OD (outside diameter) of the new alloy pipe will need to be the same (give or take a couple of mm) to the OD of the airbox exit and intake manifold.
to measure the OD of the to the airbox exit and intake manifold (which should be the same) get a tape measure and place it across the widest point  :wink:
Offline dan23
« Reply #8 on: 12 April 2008, 13:48 »
cool cheers for the info
Offline dan23
« Reply #9 on: 12 April 2008, 14:33 »
ok guys, help is much appriciated, but i still need some help lol
to save time and so ppl dont tell me the same things iv got a pic of the engine, iv marked out the sizes on the throttle body and the air box so i need some help on what i need to get e.i what angle bend etc...
