Author Topic: 2000 VW GOLF GTI TURBO TROUBLE NEED ADVICE  (Read 921 times)
Offline jayunit
« on: 10 April 2008, 12:06 »
Hi Guys,
Just got towed home. my gti turbo has just packed up on me. Was driving along and with no warning started to make a funny noise, so pulled over and the car died. wouldnt tick over or start or nething, all electrics still fine but engine seems bit knackerd. AA man rekons it could be oil pump or could be a complete engine seizure??
Any advice
thanks
jamie
Offline topher
  • Administrator
  • fully functioning
Re: 2000 VW GOLF GTI TURBO TROUBLE NEED ADVICE
« Reply #1 on: 10 April 2008, 12:08 »
what happens when you try to start it?
Offline jayunit
« Reply #2 on: 10 April 2008, 12:12 »
nothing, the electrics come on but no life in the engine
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 10 April 2008, 18:48 »
Can you get the engine to turn by putting it in gear and rocking the car?
Nick
 01455 617233
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 12 April 2008, 20:14 »
Do you get a click from the starter or anything?  Usualy you get warning if its the oil pump, noisy lifters, heavy tapping, oil light?!?  and eventualy the bottom end will start clattering like crazy... THEN i would expect it to seize.
What sort of funny noise? usualy it will be a squeeky clattering knocky sound with accute pump failure.  As said before,  try to rock the car in gear.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
