Author Topic: mk1 VDO Gauges  (Read 1764 times)
Offline luckson317
mk1 VDO Gauges
« on: 09 April 2008, 20:58 »
am just fitting my mk1 with audi vdo gauges, and got the T Piece from Demon tweeks today. but it dont make sense, if you screw the oil temp sensor in the side first, it blocks any flow to the top hole, for second sensor, the side sensor screws all the way in, blocking flow to top.
Has anyone else had this problem??
Offline ian007miles
Re: mk1 VDO Gauges
« Reply #1 on: 10 April 2008, 13:08 »
hi mate i had this proplem wen i done mine all i done was put a washer inbatween the sender and the t peice and it work perfectly
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
