Author Topic: Battery draining problems  (Read 1900 times)
Offline AdamMk2
  • Beautiful
« on: 08 April 2008, 00:14 »
I am having a few problems with my Golf draining the car battery, it seems to be if you leave it for two days or so without starting it it struggles to turn over and the battery light comes on  :undecided:
The is no live feed going to an amp/sub setup anywhere, however has a scorpion full closure alarm (Doubt this could do anything!!)
It has just had a new Alternator and battery so theres no problem there either!!!
Anyone experienced similar problems before???
Thanks
Adam
Offline OakeyDoak16v
Re: Battery draining problems
« Reply #1 on: 08 April 2008, 00:37 »
Might be worth checking your boot light in case thats stuck on. :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 08 April 2008, 03:05 »
Wot he said was wot I was gonna say. :smiley:
Offline AdamMk2
  • Beautiful
« Reply #3 on: 08 April 2008, 07:46 »
Cheers lads, will have a look now  :wink:
Offline clipperjay
« Reply #4 on: 08 April 2008, 09:33 »
I would either buy a multimeter for £5 or borrow one!
disconect the postive battery lead and link it up tot he volt meter makes sure both voltage probes are in line i.e black probe on lead red probe on battery terminal.
Then check whats draining the car out.
The meter should read 0.5V or about 1V depending if your door is open, boot and the interior light is using ampage.
If its more like 2.5V or over start unpluging the fuses and see if the voltage drops if it does then that fuse which is linked should be the cause of the short in theory!
A new alternator does not mean the voltage regulator has not been damaged since install.
Jay
Offline Dolly
« Reply #5 on: 08 April 2008, 21:31 »
mine was draining, turned out to be the stereo, for some reason the aftermarket sony i think it was has 2 feeds, one igntion and one permanent, the permanent had been bodged into the igntion for some reason, i knew this and thought taking the front of the stereo off would surfice, but it was definatly the root of my problems.. so to get round this i fitted a G60 engine and are fitting some guages in its place  :cool: ... (although there maybe easier solutions)
Offline AdamMk2
  • Beautiful
« Reply #6 on: 08 April 2008, 23:14 »
Funnily enough you mention the stereo, It has a new Alpine iPod unit however its not quite crimp and connect, more tape and go haha so will check that. (I didnt fit it btw!)
Also Voltmeter , will get on that straight away.
Offline AdamMk2
  • Beautiful
« Reply #7 on: 10 April 2008, 08:06 »
Had a look at the head unit lastnight and someone has spurred a live from the heated rear windscreen, possibly causing problems? However I found the correct switch and permenant live I belive and now the head unit comes on when the ignition key is turned, not just when the engines on!!
Score!  :tongue:
Dads on the case to getting me a voltmeter today tho anyway, what a legend!
Offline mattkh
« Reply #8 on: 10 April 2008, 08:40 »
....... and now the head unit comes on when the ignition key is turned, not just when the engines on!!
Hi
When the engines on, the ignition key is at ON anyway.
Offline AdamMk2
  • Beautiful
« Reply #9 on: 10 April 2008, 16:30 »
What I meant was when Ive turned the key to the turn before it fires it actually works like I thought it should have done, prior to that it didnt!
