Author Topic: How much for cambelt change?  (Read 3714 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: How much for cambelt change?
« Reply #10 on: 15 April 2008, 21:42 »
£40 ish? mabey a bit less.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline mat-ryder
« Reply #11 on: 15 April 2008, 21:48 »
is that for a kit including tensioners?
Offline Mr Blue
« Reply #12 on: 15 April 2008, 21:50 »
Try your yellow pages for a mobile mechanic.
They can charge less than garages. Probs cost you £100 with parts on your door step
Offline Diluxe
« Reply #13 on: 16 April 2008, 23:25 »
i think 120 would be about right considering tensioner and belt is about £50 quid of that, based on gsf prices.
you could do it yourself it not actually a difficult job , just get everything timed up before you undo the tensioner & do it when the engines cold.
rope a mate in you could do it in under an hour on your 1st attempt  :wink:
1997 16V
Offline Rmachines
« Reply #14 on: 16 April 2008, 23:31 »
I get my cambelt kit with new tenssioner etc.. for £24.00 and thats not on trade,  its £18.00 trade.  thats a powergrip kit which are pretty good.   I wouldnt pay more than £40 for the kit then £80 fitting.
Offline mat-ryder
« Reply #15 on: 16 April 2008, 23:54 »
where do you get your kits from?
Offline bored_Welsh_lad
« Reply #16 on: 17 April 2008, 09:10 »
gsf/euro car parts/gmf
cheap as chips
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline mark3valver
« Reply #17 on: 17 April 2008, 10:29 »
you can just buy the cambelt and convert it to a mk2 style tensioner as the MK3's are renowned for being rubbish esp when replaced with a non VAG kit....
the best suggestion is a mobile mechanic if not doing it yourself......
does anyone know how much a garage would charge to reset my timing and CO2?......
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline Hypermonkey
  • Only users lose drugs!
« Reply #18 on: 17 April 2008, 13:23 »
also get the water pump changed at the same time as they have a history of being poor...especially the original ones. This will add £50ish to the bill but if you replace the belts and the pump goes...have to do them all again so extra expense  :angry:
Offline whit
« Reply #19 on: 23 April 2008, 15:38 »
is it worth buying a genuine VW belt & tensioner? (how much are they from VW?)
are GSF/euro parts just as good?
