Author Topic: Difficulty selecting Gears when cold???  (Read 2670 times)
Offline NickJ76
« on: 07 April 2008, 10:24 »
As per title any ideas why sometimes especially when cold ( 1 or 2 degrees) its difficult to select gears especially 1st. As car warms up problem goes away. Tends to crunch when selecting reverse as well. Its a 2000 Gti??
Offline ub7rm
Re: Difficulty selecting Gears when cold???
« Reply #1 on: 07 April 2008, 12:38 »
Yeah I have the same problem, not the first time I try and get 1st, but after that till warm its a bit of a bugger......
2020 BMW 128ti
2017 Golf GTD Estate
Offline GTi-Matt
« Reply #2 on: 07 April 2008, 17:45 »
gear box oil maybe?
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Trickyboy
  • MK5 GTi 3dr Reflex Silver
« Reply #3 on: 07 April 2008, 18:31 »
me too! mostly first, occasionally second, until warm.
Offline NickJ76
« Reply #4 on: 07 April 2008, 21:16 »
I wondered about gearbox oil but havn't the foggiest on how to check. If all you guys are having same prob someone must know why on forum, surely??? Souns like a common problem!!
Offline Ashmond
  • Money, b!tches And Boost
« Reply #5 on: 08 April 2008, 11:27 »
mine did it on the 1.4 and the 1.8t
Offline ub7rm
« Reply #6 on: 08 April 2008, 13:00 »
TBH I think its a common problem on every car I've ever driven old or new that from cold, and especially in first/second the gear box is a bit notchy.
2020 BMW 128ti
Offline dudz
« Reply #7 on: 08 April 2008, 13:56 »
Same here, only when going into 2nd though, until it gets warmed up
Offline GTi-Matt
« Reply #8 on: 08 April 2008, 14:12 »
its happened to me before and i put it in to neutral again and pumped the clutch and that always works :afro:
Offline rheady
« Reply #9 on: 10 April 2008, 14:28 »
The brake fluid also supplies the clutch master cylinder and it is advised to change the fluid every 2 years. Might be you fluid needs changing.
