Author Topic: clutch/gearbox noise help please  (Read 1219 times)
Offline olliemk2
« on: 06 April 2008, 15:08 »
my car makes a groaning noise when changing up the gears, only for about a second though. It also only happens under full throttle a t high revs 5,000 rpm or higher, is a little worrying though. The gearbox is great, no crunching at all or whining, and the clutch has done less than 1000 miles, all gearchanges are very smooth and nice, its annoying because its putting me off booting it, if i change up a gear below 5,000rpm it dosent do it. Sounds like its coming from the engine bay, definitely not the gearbox. car pulls like a train still. Any ideas on what this could be would be most appreciated, thankyou very much. :sad:
Offline boneybradley
  • Back in a Mk3...
Re: clutch/gearbox noise help please
« Reply #1 on: 06 April 2008, 15:39 »
engine/gearbox mount?? worth checking them all out.  or drive slower??
Offline olliemk2
« Reply #2 on: 06 April 2008, 16:22 »
i cant notice any difference in performance, still seems to go great, could this be a mounting then cos it dosent make any noise when not under full throttle, you dont think its anything serious then?
Offline Kenny_1.6
  • it will be a GTi... some day... lol
« Reply #3 on: 08 April 2008, 18:09 »
am sure someone told me recently that some VW engines were limited to 5000rpm when the car is in neutral... not sure if this is just newer models (pretty sure the guy who told me is my mate who drives a Mk5) or if its been on the go for years  :huh:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 12 April 2008, 20:11 »
I have had mine bouncing off the limiter in neuteral  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline mk2mark
« Reply #5 on: 15 April 2008, 20:44 »
Sounds like your clutch slipping, depending on what you mean by groaning.
Offline rombonie
« Reply #6 on: 15 April 2008, 23:55 »
I agree with it being the clutch and probable a spring or two in plate, be ready for it giving up the ghost
