Author Topic: Head gasket needs replacing any other jobs to get done at the same time  (Read 968 times)
Offline dready chris
Just had my headgasket tested today, looks like it needs replacing . The mechanic tested the coolant for gases and said it was showing traces of them indicating that it's on the way out. Was wondering if there there any other jobs which would be a good idea to get done at the same time while the head is off.
The car is a mk3 gti 8v.
Chris
Offline JC
  • Back in the North.
cambelt  :wink: you would be amazed how many people dont  :shocked:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Always change the cambelt,  i do it even if i changed it a month or so before,  Change the tenssioner as well!! (usualy a kit anyway)  While thats off to the water pump and thermostat.
Also.. depending on how/why the gasket blew.. Have the head checked, if its noisy its a perfect time i slip a new set of lifters in there ;)   If your into that kinda thing.. you can have a go at porting/polishing your head while its off.   I painted my rocker cover a very nice silver while i had mine off.
Oh.. a new exahust and manifold gasket might go down well if its been disturbed  :evil:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Conker
You could get the head skimmed, look at valve stem seals replacement, replace valve cover gasket and replace the exhaust manifold nuts (and studs if you can be bothered) while your at it.
