Author Topic: Mk2 16v gearbox swop  (Read 893 times)
Offline e700
« on: 05 April 2008, 19:52 »
Hi,
Is it possible in changing the 5th gear on my 1988 16v gearbox to one from a 4e box? if so is it a big job to do and will i benefit from better mpg, noise levels etc at motorway speeds?
1988 Monza Blue 16v
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Mk2 16v gearbox swop
« Reply #1 on: 05 April 2008, 20:15 »
Yes it can be done. There is no literature in the haynes about it, but there is  web site link to the procedure. I did mine on my old 8v without looking at any books, and as long as you are carefull and record various measurments during dismantling, you should be ok.
You need to drain the gearbox oil first, jack up the front of the car and remove the front left road wheel. You then need to remove the engine\gearbox mount and mount strut, then locer the gearbox down sufficiently to gain access to the 5th gear cover. Carefull with the gasket as you will need to use this again.
Be carefull which rods you remove as there is one that if removed, is a gearbox out and dissassemble to refit it.
I will look for the website  for the rest of the proceedure and post if I find it.
It took me about 3 hours to do the job, but then I am an engineer anyway and am quite used to doing things like this.
Offline DarnPB
« Reply #2 on: 05 April 2008, 20:24 »
Offline e700
« Reply #3 on: 05 April 2008, 20:38 »
thanks very much for your help
1988 Monza Blue 16v
Offline Conker
« Reply #4 on: 06 April 2008, 10:04 »
Thats a proper "5 spanner" job !!  Well fiddlly.
