Author Topic: Extremely expensive pop rivets  (Read 1028 times)
Offline dadrathers
« on: 05 April 2008, 19:50 »
OK heat shield above rear exhaust box is held on with 'star' washers clamped onto pins sticking down from the underside of the car. One had rusted enough to allow the corner of the heat shield to drop onto the exhaust - nice tinny rattle. OK me thinks get to the stealers and buy some new pins and star washers - replace them all on this heat shield while I am at it. Nooo! Star washers are pence but these pins that are called pop rivets in ETKA are £5.50.... EACH.
Anybody had similar prob and how sorted?
Cheers.
Offline JC
  • Back in the North.
Re: Extremely expensive pop rivets
« Reply #1 on: 05 April 2008, 20:06 »
i used some aluminium foil tape from work and " reinforced " them - worked a treat
Offline rowlers
  • I'm back - MK7 GTI
« Reply #2 on: 06 April 2008, 09:08 »
can you not just use normal rivets, with a washer?
Offline Conker
« Reply #3 on: 06 April 2008, 09:54 »
This happened to me only just this week.  Check out my ghetto fix: I used exhaust paste to fix a nut onto the pin (like a glue).
 :drool:
Offline jammac
« Reply #4 on: 06 April 2008, 13:48 »
good old speed tape ay chuff
ITS A TRAP!
