Author Topic: Connecting sub to amp...  (Read 5630 times)
Offline dan23
Re: Connecting sub to amp...
« Reply #10 on: 06 April 2008, 15:24 »
right if your running your front speakers via the amp then all you do is run wires from the speakers directly to the amp.
the reason for the remote is so it turns on and off via your stereo, so everytime the stereo is off the amp is off.
if you follow the diagram i made you make you will have no problmes wiring it all up
Offline Shady Pioneer
  • graphic designer.
« Reply #11 on: 06 April 2008, 15:27 »
Yeah I had a look at that, thanks for doing that  :smiley:
That's cool then, all I need to do now is buy all this stuff and get it all fitted, the hardest bit will be wiring the power cable to the front, I just don't know where I can get the cable through to, how do other Mk3 users get around this?
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 06 April 2008, 15:30 »
behind the glovebox is a grommet thats routes the alarm wires inside the car (look mid way up left hand side of engine bay)
  • graphic designer.
« Reply #13 on: 06 April 2008, 15:38 »
Good man  :grin: thanks for that, will have a look in a bit for that.
I assume that means I don't have to fill in any holes with anything or what not, it'll be simply thread the power cable throught the same hole as these other wires?
  • Back in a Mk3...
« Reply #14 on: 06 April 2008, 15:46 »
I cut/modified the original grommit and reused this...but you need to remove the glovebox to thread the wire through
« Last Edit: 06 April 2008, 16:02 by boneybradley »
  • graphic designer.
« Reply #15 on: 06 April 2008, 15:54 »
Oh really? Damn...I kind know what I'm doing but I don't wanna end up screwing my car up by doing this lol!...
  • Back in a Mk3...
« Reply #16 on: 06 April 2008, 15:56 »
lower glovebox has 6 bolts and the upper about 8... should be simple to do?
  • graphic designer.
« Reply #17 on: 06 April 2008, 15:59 »
Oh hold, in your last post did you mean glovebox? LOL! You said gearbox  :drool:
Offline dan23
« Reply #18 on: 06 April 2008, 16:51 »
lol :laugh: :shocked: :tongue:
  • graphic designer.
« Reply #19 on: 06 April 2008, 17:07 »
Oh yeah, go and change it now to make me look a fool LOL! Thanks for the help though man, will keep people updated on the audio system  :grin:
