Author Topic: Help changing cambelt on a mk2 8v gti  (Read 1094 times)
Offline Matt106
« on: 05 April 2008, 13:40 »
Ive recently been changing the head gasket on my mk2 8v gti and its now come down to putting it all back together but i cant seem to get at the cambelt to change it. Do i need a special tool to remove the other belts first before i change the cambelt or is ther an easier way?
Offline Conker
Re: Help changing cambelt on a mk2 8v gti
« Reply #1 on: 05 April 2008, 14:02 »
I'm better with 16v'ers, but you'll prob need to remove the vibration dampers (sprockets), the PAS sprocket if present, and then the upper and lower cam covers. To loosen the belt, undo the cam belt tensioner.
I would invest in a Haynes!! Not sure how you did the HG without one??
Offline rombonie
« Reply #2 on: 05 April 2008, 14:26 »
Yep all the other belts have got to come off!
A haynes would be best bet me thinks :)
Offline Matt106
« Reply #3 on: 05 April 2008, 14:43 »
Ive got a haynes but its not detailed enough to be honest didnt use it once removing the head. To remove the vibration dampers do you need a special tool as it looks like one is held on with a big star shaped nut?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 05 April 2008, 14:54 »
Its easy to take them off, you just loosen the mounting bolts and turn the toothed adjuster thing, the belts will just come off.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline DAVEMARX
« Reply #5 on: 15 April 2008, 19:06 »
if buy any chance you put it all back togeather and it all goes wrong and blows up is ther any chance i could have your gearbox...cheers m8 :evil:
