Author Topic: what does this mean  (Read 11518 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
what does this mean
« on: 04 April 2008, 10:37 »
plugged vagcom in the other day and it came up if this.
internal contr module.rom error
the code 16989
rom error does not sound good to me but the car is running great,really do not know what it is help please
Offline gtitdi
Re: what does this mean
« Reply #1 on: 04 April 2008, 10:41 »
i'd try clearing it and see if it comes back
can mean a faulty controller but most of the time its just a communication error between vagcom and the controller, so not important
Offline (shakey)
« Reply #2 on: 04 April 2008, 10:44 »
what is it and wear can i find it.
tar
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 04 April 2008, 11:33 »
I think when he says clearing it he means clear the fault on VAGCOM.
Offline gtitdi
« Reply #4 on: 04 April 2008, 14:16 »
yeah  :smiley:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 04 April 2008, 18:36 »
Is this the first time you have used Vagcom on this car?
A Vagcom ROM errom can be down to wrong software on the ECU Chip?
If you can read all the other controllers with vagcom and the ROM error keeps comming back then your remap software can be incorrect or currupt.  But dont take my word 100% yet.
Nick
 01455 617233
Offline (shakey)
« Reply #6 on: 05 April 2008, 13:52 »
Nick
yes it is the first i have used it but evertime i go to clear the code and do tb enlinement it wont let me because the code keeps comin bck.
Offline RTechUK
« Reply #7 on: 06 April 2008, 10:42 »
I am 99.9% sure you have the wrong software in your ECU  :undecided:
The 1.8t ECUs have a few variants of hardware numbers and each hardware version has a few different software revisions. If you put the wrong software vervision on the ecu you will get a ROM error  "READ ONLY MEMORY" which is fixed inside a eeprom chip. The car will run and work but not 100% as the map areas will be wrong.
Whats your ECU HW number?  It should start with 0261********
Nick
 01455 617233
Offline (shakey)
« Reply #8 on: 06 April 2008, 17:39 »
Nick
hi where will i find the ecu should now but there go
Offline richw911
« Reply #9 on: 06 April 2008, 18:10 »
Nick
Under the wipers plastic panal  :smiley:
