Author Topic: is this right?!  (Read 3083 times)
Offline gtitdi
is this right?!
« on: 04 April 2008, 10:34 »
looking at the prices of new front wings cause I've got a bit of rust underneath the arch
VW - £102 + VAT
GSF - £26.50 inc VAT
Can that be right?!
Offline Rhyso
Re: is this right?!
« Reply #1 on: 04 April 2008, 10:39 »
on the actual galvanised body?? MKIV came with a 12 year anti-corrosion warranty; maybe worth pushing that.
those prices are probably true as GSF usually stock 'pattern parts'  w
what you'll find is that they may not fit properly and you'll spend more money at the bodyshop getting them to fit.
you pays your money, you takes your chances
Offline gtitdi
Re: is this right?!
« Reply #2 on: 04 April 2008, 10:51 »
yeah, here's a pic
you reckon it'd be covered? same on the other side too
Offline Rhyso
Re: is this right?!
« Reply #3 on: 04 April 2008, 11:03 »
is it on the inside coming out or the outside rusting in??
if there's rust on the inside then i'd say push for it.  If its rusting on the outisde then i don't think you'll be covered.  It had a 6 year paint warranty but obviously only if any damaged was repaired and not neglected
Offline GTi-Matt
Re: is this right?!
« Reply #4 on: 04 April 2008, 11:28 »
does it really? :shocked: on my V reg i have rust bubbles starting to come through underneath the rear window, how do i go about sorting that out? :undecided: :undecided:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline GUY_GTI
Re: is this right?!
« Reply #5 on: 04 April 2008, 11:36 »
ive never seen one rust like that before, must have had a chip and got water in? mine has a slight bubble where my front mud flap used to be, cause more damage than protection
watch the sump ask guy he went over a some toilet paper and it carcked!!!! :laugh: :laugh:
