Author Topic: Ignition supply and idzz markings.  (Read 957 times)
Offline paul73
« on: 02 April 2008, 22:26 »
Hi, I have a MK3 gti and having great fun sorting out the stalling/idle problem.
I have been told that the problem can be cuased by the ECU not supplying 12.5 volts to the coil and need to find out how to check this. any ideas?
Also i have just fitted a new dizz. Apparently there are markings to show TDC for cylinder no1 on the dizz? Does anybody know were the marks should be as it looks like mine is 180 degrees out and should it still run if this is the case?
Please help
Thanks
