Author Topic: headlining?  (Read 3304 times)
Offline antogoof
  • bbm mk2 g60
headlining?
« on: 02 April 2008, 16:09 »
i have just bought a mk1 which needs the headlining redoing or cleaning, i would just like to know how much it would cost for a retrim, i have been on DB cartrim`s website and it has a typical price of £65 for a mk1 gti so i can get a rough idea off that. at the moment all i know is the headlining is moldy so if it is still intact i will just want to clean it for now. can anyone recommend a good cleaner for this? thanks in advance. :smiley:
mk2 bright blue met bits wanted in north west.
Offline maaarcooose
Re: headlining?
« Reply #1 on: 02 April 2008, 16:21 »
I've just been cleaning the headlining of my rather mouldy cabriolet.
I used W5 window cleaner, basically Windowleen and a nail brush to scrub the mould off and wiped off with an old towel. It's come up a treat.
The brush helps get into the texture of the headlining.
I thought I was going to need new headlinign till I did this.
!m!
Offline antogoof
  • bbm mk2 g60
Re: headlining?
« Reply #2 on: 02 April 2008, 16:29 »
cheers for that matey, the only problem is im not sure how bad it is! apparantly there are no rips in it but if is sagging im gonna be fooked! i will have to wait and see.
Dinky
Re: headlining?
« Reply #3 on: 02 April 2008, 19:31 »
Ensure that you lining has been fitted correctly, well your hood in general
looksee - http://www.golfgtiforum.co.uk/index.php?topic=34662.0
Also, I remember Gibby mentioning something about the "stuffing" (i dont know the correct term) is all in place and it tact as this can obviously cause saggin with the hood..
Like M said, your best bet would be to buy yourself some cleaner and get scrubbing - best way to find out for yourself if there are any rips or snags :smiley:
Guys...quick note, if you do replace your hood, i was always advised to give it a 7 day "rest" period before actually operating it..
Dinx :kiss:
« Last Edit: 02 April 2008, 19:33 by Dinx »
Offline maaarcooose
Re: headlining?
« Reply #4 on: 03 April 2008, 07:23 »
Dinx :kiss:
Great idea that. I'll make sure I do that when I replace mine.
Thanks Dinx. Any other super tips on replacing the hood?
!m!
Dinky
Re: headlining?
« Reply #5 on: 03 April 2008, 18:24 »
Ill tell you when I grow the b@lls big enough to remove mine for to do the rear window :grin:
Have you checked your rear window btw? as they can rust bad!
Dinx :kiss:
