Author Topic: fitting coilovers, any other other parts needed?  (Read 1387 times)
Offline Dibz
« on: 01 April 2008, 16:06 »
Ive got a set of coilovers that I am going to fit to my '86 MK2 8v gti but I'm wondering what other parts if any are need to fit them or if there's parts that are worth changing while I'm swapping the suspension?
I've bought some new top mounts for the front but do I need anything else for the rear?
Offline MarkS
Re: fitting coilovers, any other other parts needed?
« Reply #1 on: 01 April 2008, 17:32 »
Maybe new suspension bushes is yours are looking a little worn pal?
VeeDubGTI16v
« Reply #2 on: 01 April 2008, 18:01 »
you might as well change the rear top mounts too
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 01 April 2008, 18:50 »
I've just got some rear shock top mounts for mine for under £2 each from vw! well worth swapping
Offline kerrly
« Reply #4 on: 04 April 2008, 16:36 »
you could use it as a opportunity to go to town so to speak. Id start by pressure washing inner arches and underneith then covering every nut/bolt with degreaser followed by quick rinse and some WD40 or similar just to make life easeir.
Before removing old suspension mark up roughly where lower suspension connects to hub to give  idea where to allign it to when you put new suspension on. once old suspension off...
- front top mounts - G60 ones if you can get hold of them
- track rod ends - tracking and camber will need doing after shocks fitted so might as well.
- ball joints
- anti roll bar drop links and inspect ARB clamps under car.
These will make a drastic difference to the cars handling!!!
you also may want to get calliper paint- again might as well do as many lil jobs as possable whilst suspension is off
Enjoy :smiley:
Dave
Offline mark3valver
« Reply #5 on: 07 April 2008, 08:53 »
agree with above if you have the £Â£Ã‚£ to do it.
As a minimum, I will be doing top mounts, and bushes when I put my coilovers next month... then an alignment check a few weeks later after letting them bed in for a little while.....
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline remapped
  • If you are going through Hell, keep going
« Reply #6 on: 07 April 2008, 09:39 »
get the VR6 top mounts form a a mk3 they are perfect for mk2s and 3s they are around £20
i haven't fitted mine yet as i have made a list of tools which will i need, if you fitting yourself i highly recomend d using borrowing good HQ tools
OEM(ish) G3GTi 8v5dr
