Author Topic: trouble with third.  (Read 1402 times)
Offline jonezee_ipswich
  • Golf Mk 2 1.8 Gti
trouble with third.
« on: 31 March 2008, 17:39 »
Hi all.
just some advice if i may.
Sometimes but not all the time I have a strugle to get the car into 3rd gear. but if i wiggle the stick abit it will go in.
Now im thinking it might be the syncro in which case id need a new box.
but could it be the selector cable?
just wondering if anyone has heard of this?
Im not sure but if it was the cable surly i would strugle with reverse, 3rd and 5th?
Thanks in advance. :wink:
Leon R
Re: trouble with third.
« Reply #1 on: 31 March 2008, 20:33 »
....  :grin:
Do you have any gear stick play in neutral or in gear? Forward/backward movement or side to side play?
  • Golf Mk 2 1.8 Gti
« Reply #2 on: 31 March 2008, 20:38 »
Nope none at all.
  • Golf Mk 2 1.8 Gti
« Reply #3 on: 31 March 2008, 20:39 »
lol just got that myself! what a mug  :grin: :grin:
Leon R
« Reply #4 on: 31 March 2008, 20:49 »
A second gear crunch is something infamous on mk2's due to the fact people do a rushed change ("racing start") from 1st to 2nd and fudge it up, the more it happens the more damage occurs. The start of the syncro wearing would be a notchy gear change, possible crunch when the gearbox oil isn't up to temp but when it is quite worn you would hear a bad screech/crunch. 3rd gears have been known to have this same problem too.
Check the plastic linkages for cracks, the relay shaft ball etc for correct location (maybe post a pic) then after you could try changing the gearbox oil. This will not cure the problem, but just mask it unfortunatley.
New box is pretty expensive so hope you find its something else.
Leon R
« Reply #5 on: 31 March 2008, 20:50 »
I'm very immature lol!
  • Golf Mk 2 1.8 Gti
« Reply #6 on: 31 March 2008, 20:55 »
I've got a kit that came with the car. Is this the bush that stops play in  the lever?
Where would i find it? lol
 oh and cheers for the help btw!! :cool:
Offline Jay
  • balding fat cvnt
« Reply #7 on: 31 March 2008, 21:14 »
Stolen from clubgti  :laugh:  (probably on here somewhere?)
http://www.clubgti.com/forum/archive/index.php?t-83271.html
  • Golf Mk 2 1.8 Gti
« Reply #8 on: 31 March 2008, 21:24 »
thanks mate will have to give that a try!!
Took my car for about a hours lash a little while ago and was fine.
Thats how tempromental it is!
