Author Topic: MY GTI IS SINKING  (Read 2335 times)
Offline lurber
MY GTI IS SINKING
« on: 28 March 2008, 19:40 »
HI DUDES, I SEEM TO BE GETTING LOTS WATER IN MY REAR PASS SIDE FOOTWELL, ANY IDEAS WHERE IT IS COMING FROM, CHEERS MARC. 2 DOOR MK1 GTI
Offline gibby
Re: MY GTI IS SINKING
« Reply #1 on: 28 March 2008, 19:54 »
Have a look at this thread see if it helps at all. http://www.golfgtiforum.co.uk/index.php?topic=19411.0
......now officially dubless.
Offline lurber
« Reply #2 on: 28 March 2008, 20:08 »
DONE ALL THAT, DRAIN HOLES OK, SEALS OK JUST SEEMS FUNNY ITS ONLY IN THE BACK PASS SEAT, :cry:
Dinky
« Reply #3 on: 28 March 2008, 21:38 »
Checked the sunroof, if you have one?! :undecided:
btw...when you park the car, is it on a flat surface or on a hill of some sort?
Have you actually poured some water over the whole car and then checked to see if any water is actually in it once you have finished?
Dinx :kiss:
« Last Edit: 28 March 2008, 21:44 by Dinx »
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #4 on: 28 March 2008, 21:41 »
what kind of GTI are we talking about here? Cab or tin top?
forget the question just seen 2 door GTI.
you might want to check the outside roof, to make sure there is no holes near the rain drains. Also do you have a stereo ariel on the roof, sometimes this leaks water.
« Last Edit: 28 March 2008, 21:43 by Madone_si »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline lurber
« Reply #5 on: 29 March 2008, 19:48 »
CHEERS DUDE, SUN FOOF IS OK I THINK, I DO HAVE A RADIO AERIAL SO I WILL CHECK THAT OUT IN THE MORN. WHERE ARE THE DRAIN HOLES. I HAVE LOOKED AT THE ONES IN THE DOORS AND THE TWO UNDER BONNET. THANKS IN ADVANCE MARC
Offline rustys_mk1
« Reply #6 on: 08 April 2008, 23:25 »
Check your tail lights aren't letting water in as they have a rubber seal around them where they meet the body and it may have perished letting water run through the boot and into the rear footwell......
