Author Topic: 25th anniversary gti turbo  (Read 1727 times)
Offline zooropean
« on: 28 March 2008, 19:16 »
anyone else have warning light trouble with their anniversary? only i've had mine for a couple of months now and the engine management light has popped up a few times. been told it's nothing major just a heat sensor or something
just wondered if this is a common fault as im a little concerned
cheers
Offline richw911
Re: 25th anniversary gti turbo
« Reply #1 on: 28 March 2008, 20:09 »
You need to get it plugged into vag com or a fault code reader- Prob only a sensor the temp sensor is a common fault of the 1.8T engine.
You should post in the mk4 section - you will find a lot of help there :afro:
