Author Topic: Idle troubles got me in trouble!  (Read 1034 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 27 March 2008, 21:24 »
I was waiting in the drive through of Mc Donalds with my Daughter earlier. I was sat behind a Police Astra. My idle started going from 700-1700. After about 3-4 mins of waiting in the que the passenger copper came up to my window and asked why I kept revving up behind them. Whilst he was talking I showed that I was not touching the throttle and it was revving on its own, he laughed when he saw!  What was wierd was as soon as I turned my lights off and heater off my idle went to around 850.....result.....  not for long though as its returned!
Offline jezza16v
Re: Idle troubles got me in trouble!
« Reply #1 on: 27 March 2008, 22:02 »
Hi, extract from Canadian Digi site...........seems familiar!   :smiley:
Idle Stabilizer Valve (ISV)
Dirt in the Idle Stabilizer Valve (ISV) is a likely cause of erratic idling and stalling, especially when the air conditioner compressor cuts in. A dirty ISV will cause the car to not idle at all, or may cause the idle to lope  up and down between 700 and 1500 RPM.
The ISV sits on top of the engine just behind the valve cover and in front of the intake manifold. It is designed to allow a metered amount of air to bypass the throttle valves depending on engine load, temperature etc. to maintain an even idle speed.
To clean the ISV, remove the valve from the engine.  Spray the ISV liberally with carburetor cleaner or throttle body cleaner. Use rubber gloves and work outdoors because this cleaner may contain toluene or xylene or both. These chemicals are extremely nasty.
Don't use brake cleaner - it can destroy plastics and rubber. Also, brake cleaner contains perchloroethylene, an even scarier chemical. Definitely try to avoid breathing any of this stuff.
After taking precautions, spray the cleaner into all three openings in the ISV and allow the black gunk inside to drain out. Carefully use a small piece of wood as a scraper to clean up the interior of the valve. Try to get the metal inside as clean as possible. Spray again and repeat until it sparkles inside.
ISVs do fail outright and then you are faced with an relatively expensive fix. At least the part is easy to replace. But before installing a new ISV, always try carefully cleaning the old one first.
A properly working Digifant idle stabilizer is effective enough to allow a manual transmission car to creep along at idle speed without stalling.
Offline DAVEMARX
« Reply #2 on: 11 April 2008, 21:47 »
IF ALL THAT FAILS TAKE A TRIP TO THE CSRAPPY AND POCKET A FEW. SOME AUDI 80S HAVE THE SAME ISV HAD THE SAME PEOB WITH MINE SWOPED IT FROM AN AUDI CLEANED IT UP AND IT WORKED A TREAT.
Offline Jay
  • balding fat cvnt
« Reply #3 on: 11 April 2008, 22:00 »
Cheeky copper laughing ...
DAVEMARX, do you know what the CAPS LOCK is for? :lipsrsealed:
Offline DAVEMARX
« Reply #4 on: 23 April 2008, 20:12 »
CAPS LOCK UUUM IS THAT PART OF A WHEEL OR SOMETHING :grin:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #5 on: 24 April 2008, 19:57 »
dude seriously lay off the lock ;)
