Author Topic: Throttle Body  (Read 1545 times)
Offline benjam_in
Throttle Body
« on: 13 April 2004, 12:36 »
Got a MK2 Gti (digifant) on the backside of the throttle body there is a hose about 10cm long with a plug in the end. does anyone know what it does? and what affect it would have if it was split?
Golf Mk2 Gti 1988
Veedubgt18v
Re:Throttle Body
« Reply #1 on: 14 April 2004, 12:53 »
it doesnt do anything but if it is split or the bung is leaking it will introduce unmetered air into the engine resulting in bad idle etc etc get some vacuum hose from vag and replace it, its worth doing all of them cos they detioriate over time, and yopu get 2metres worht from vag anyway  :)
Offline benjam_in
Re:Throttle Body
« Reply #2 on: 14 April 2004, 14:20 »
cheers its alway usefull to know stuff like that! see if i can blag some from the local vw garage!
Golf Mk2 Gti 1988
vwsystems
Re:Throttle Body
« Reply #3 on: 18 April 2004, 06:54 »
if any air enters the engine without going through the air flow meter its ment to cause lean running!
