Author Topic: does this look right or wrong?  (Read 1107 times)
Offline jammac
« on: 27 March 2008, 13:12 »
when i had my MOT done i had an advisory saying my brake load sensing valve linkage was seized. Im having a day today tampering with my golf and have had a look at it. i dont really know what exactly im suppossed to be looking at though, but here are some pics
apart from the slight leak im not sure whats supposed to be seized?
also it looks like something is prehaps missing from where my finger is pushing in the top picture? am i right or wrong?
any pointers/ advice/ critism or abuse would be helpful.
cheers J
ITS A TRAP!
Offline Steve_B
Re: does this look right or wrong?
« Reply #1 on: 27 March 2008, 13:51 »
Aha, that's the bias valve. The arm connetced to the spring will pivot on a pin pulled by the spring, but will be rusted up. Soak in your favourite lubricant to free it up or replace (about 40 new i think).
Offline jammac
« Reply #2 on: 27 March 2008, 14:11 »
ok ill give the bugger a good drenching in penetrant oil!
does everything look as it should to you? it seems like something is missing?
ITS A TRAP!
Offline Steve_B
« Reply #3 on: 27 March 2008, 16:38 »
Looks alright from this angle. If i remember rightly there's a rubber bit the spring attaches to on the arm. Don't think the bit you were pointing to matters really, more the side you can't see in the pic.
Offline opel
« Reply #4 on: 27 March 2008, 17:17 »
the arm seizes up so it wont move when more weight is put in the car. so it got to be free and working
Offline black90
« Reply #5 on: 03 April 2008, 19:18 »
Sorry for the hijack but:
Should the actual arm on the valve be spring loaded?
i.e. resistance when you release the seized bias valve without the large spring attached?
Can anyone help me here:  http://www.golfgtiforum.co.uk/index.php?topic=82159.0
