Author Topic: How to adjust/lower idling speed on 1.8 Gti 1983 Y  (Read 2655 times)
Offline tajbhambra
Hi all, my MK1 idles around 1100rpm once hot and I'd like to get it down to around 800rpm if possible. Where exactly is the screw to do this?
Cheers guys
Offline leeroy20vt
  • h reg mk2 gti
Re: How to adjust/lower idling speed on 1.8 Gti 1983 Y
« Reply #1 on: 27 March 2008, 12:10 »
not sure but is it a allen key on the top of the air box or is this the air/fuel mixture ?
« Last Edit: 27 March 2008, 12:12 by leeroy8v »
Offline R11ysf
« Reply #2 on: 27 March 2008, 13:38 »
The screw is a 7mm hex headed bolt on the back of the inlet manifold.
Hope this helps.
Offline tajbhambra
« Reply #3 on: 27 March 2008, 14:51 »
Thanks, is it safe to turn this till you get the desired effect, or will it effect emmisions etc..? I thought there was a CO screw to deal with as well?
Thanks again
Offline grungeisdead
« Reply #4 on: 27 March 2008, 15:39 »
i normally keep my mk1s idling at 1k, you need to adjust your idle screw at the back of the throttle body on the right hand side of the inlet manifold.
there is the co screw on the metering head but unless you have a gas analyser i wouldnt bother messing with it, take it to a garage and ask them to set it up  shouldnt cost more than 20 squids
