my car is losing boost. Iv had a remap which should produce 14psi. In 2nd gear it only peaks at 12psi tho and when the revs get to about 4 1/2 - 5k the boost falls drastically to about 5 or summat. When in the other gears i do get 14psi. I obviously havent been able to test whether the boost falls off at the higher revs in the other gears but I'm told that it does as it was on a rollin road tother week.
When it was on the rollin road, after gettin the remap done the bhp was 169, which is quite a way off what the remap should produce. Should be lookin at 195ish.
Any ideas as to what could be wrong wi me car? Iv done a bit of a look around at my hoses etc and i cant see a split. Iv also took off the DV (forge split-r) and put it back on again, tightened everythin but that didnt do anythin.
