Author Topic: help ....oil in water  (Read 1936 times)
« on: 12 April 2004, 14:24 »
please can anyone with any advice help me i have (lots) oil in my water and just before i stopped the engine i got an low oil pressure buzz....i have done the cylinder head, skimmed new bolts gasket the lot it is now running again although very bad and lumpy (need to get some timing done i think ) but still it puts oil in water yet engine oil is fine in colour any one with the slightest idea please help as i am car less and the wife is pushiung to scrap it as its been off road for nearly 2 weeks and i have already spoent a small fortune...is it worth spending more or just buying an old ford mondeo?!?!?
its a digifant mk 2 gti 1.8 8v h reg engine code pb :-[ :( >:(
Offline greenhornet
Re:help ....oil in water
« Reply #1 on: 12 April 2004, 16:11 »
Hi.
I had this problem once with my car. Basically some water ed the oil, but not enought to knacker  it. The falult lay with a crack in the oil cooler, so I bypassed it. Disconnect the two pipes entereing into the oil cooler and place a short metal pipe inside each end, push the ends together then using jubiliee clips tighten.
Presto, should prevent any oil into the water. You'sll have to flush your radiaort and other coolant pipes out with loads of water, preferabllly from a hose to dislodge any brown gunk, but i've had no problems  with mine since. Also maybe good time to invest in new radiator and watter pipe that enters into the side of the cylinder head from the out pipe of the heater matirix.
Hope this helps.
Green.
« Reply #2 on: 12 April 2004, 16:18 »
cheers mate i will give it a go see what happens although i did test the oil cooler with tap pressure and it did not leak although this may have not been enougth pressure ta  again
Veedubgt18v
« Reply #3 on: 12 April 2004, 17:13 »
your right tap pressure prob wasnt enough!
