Author Topic: Think I have found the problem with my heater matrix...  (Read 2412 times)
Andy Jeffries
Okies...everyone look at this pic please...
Look at the valve thing to the left of the pipe that goes into the matrix...the water enters this valve hot but does not get through to the actual matrix..and the exit pipe - right one - is totaly empty so I think thats where my issue is..
so..what is this valve...what does it do..and where can i buy a replacement and what the hell am i asking for!?
cheers all!!
Offline brynmk2
Re: Think I have found the problem with my heater matrix...
« Reply #1 on: 22 March 2008, 15:50 »
when it heats up from the water it should open and allow hot water to pass through. The valves knackered, either replace it or stick a straight through bit of pipe in it. Its just there to allow the engine to warm up quicker iirc?
« Last Edit: 22 March 2008, 16:13 by brynmk2 »
Leon R
« Reply #2 on: 22 March 2008, 15:56 »
Its called the Heater Matrix By-Pass valve. It was a recall part for Mk2's to stop the heater matrix blowing hot coolant on the passenger's legs.
You could try VW themselves or check a scrappy
Andy Jeffries
« Reply #3 on: 22 March 2008, 16:04 »
what im gona try is put a t piece in to see it the matrix works (just had a genuine vag one put in, silly me should have asked for a mk3 one!) then if it works try and get the part :)
Andy Jeffries
well, it works with a t piece in so I now have to find a bypass valve...
So nice to finally have heat :)
Offline Dolly
« Reply #5 on: 22 March 2008, 21:06 »
i changed my matrix today, im putting A G60 into mine so the bay is empty at the moment, thinking about getting some copper pipes to replace these valves, is there anywhere to remove the valve inside and retain the plastic tubing?
will investigate abit more tomorrow althought getting the engine in takes priority.
Offline cняis
« Reply #6 on: 22 March 2008, 21:48 »
get a mk3 matrix and then you dont need the bypass valves.  :wink:
Andy Jeffries
« Reply #7 on: 22 March 2008, 23:06 »
I know....I did ask the garage to use a mk3 one but they didnt listen as always!!
Offline Dolly
« Reply #8 on: 23 March 2008, 07:02 »
ive put a mk3 one in mine, is it just a case of removing the valve and putting some pipe in its place?
Offline Uruk Hai
« Reply #9 on: 23 March 2008, 08:53 »
I could be wrong but I thought that places like GSF stopped selling the MK2 matrix and just sold the stronger MK3 part instead ?
