Author Topic: Car in bits HELP PLEASE - Suspension / bump stops  (Read 1052 times)
Offline T72
« on: 21 March 2008, 11:18 »
Hi,
Got the car it bits at the moment. Not sure if I'm putting the rear suspension together properly [:o]
Rear suspension all came apart ok, top spring mount in good condition, old bump stop is goosed;
I've got a Bug pack poly bush kit, it's not clear what is what, I think these are replacement bump stops ??? [:s]  [:s]
Assuming I've not got this completely wrong I assume the three pieces go together like this;
If so does it fit on the shock like this ?? It's seems wrong and it slops around on the shock, it's not tight on like the original and is a lot smaller ??
Should I put the cover over the top of these (the bit on the right in the first picture) ??
Thanks,
J
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Car in bits HELP PLEASE - Suspension / bump stops
« Reply #1 on: 21 March 2008, 16:08 »
From what i can see that looks correct,  Not sure if it is supposed to be loose but it wouldnt make to much diffrence?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 21 March 2008, 17:21 »
with it beign loose makes no diff, as then they are pushed on theyll mvoe about the strut anyway.. and theyre shorter for if youre lwoering i would suspect, so you arent riding on them..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline T72
« Reply #3 on: 21 March 2008, 19:30 »
These are for the front shocks that's why they are loose. I'll be putting the old one back on till I get replacements.
Thanks,
J
« Reply #4 on: 25 March 2008, 17:59 »
rear polys will make the ride harsh, as the bumpstops are actually part of the suspension setup which is why they're soft n foamy.  Front ones just stop the shocks bottoming out :)
