Author Topic: I Can't Compress The Valve Springs!  (Read 853 times)
Offline Conker
« on: 21 March 2008, 09:56 »
 :angry:
While I've got my head off I'm trying to change the valve stem seals. As the head is completely out of the vehicle I thought this would be an easy job.... Wrong!!!
The bucket tappets are out, so I can see the top of each valve, but the springs are SO tight, I can barely get them to move at all by hand. I've bought a spring compressor from Halfords (which has turned out to be too small anyway), but its still hand operated, so the springs won't budge.
What am I doing wrong (its a 16v by the way)??
Offline 60fast
Re: I Can't Compress The Valve Springs!
« Reply #1 on: 21 March 2008, 11:17 »
should be strait forward if you have the right spring compressor. if they feel a little tight give each one a little tap on the spring retainer useing a sutible socket to free the collets up a little
Offline Mr Blue
« Reply #2 on: 21 March 2008, 12:15 »
instead of a socket i used a metal tub and cut an access point to remove the collets.
a big G glap did the trick  :evil:
Leon R
« Reply #3 on: 21 March 2008, 13:21 »
On the right is the lever i used and even that had trouble as I had the same problem as you. But I did what 60fast said, get a sizeable socket to fit over the spring cap and give it a few taps until it gives, then use the spring compressor.
