Author Topic: fitted the gauge!! WHOOOO  (Read 2292 times)
Offline joesgti
« on: 20 March 2008, 09:44 »
Finaly after 3 1/2 hours i got it fitted.  :smiley:
Now i havnt wired it correctly as it only works when my lights are on as i couldnt be botherd going to buy a fuse. its only a 5 min job once i have a fuse and ill connect it to the fuse box and lights so it only lights up when my lights are on. i think it looks very very smart  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline gazbutmk5gti
Re: fitted the gauge!! WHOOOO
« Reply #1 on: 20 March 2008, 09:47 »
looks mint pal, how about a complete fitting guide?
Revo stg2+ & lots more
Offline joesgti
« Reply #2 on: 20 March 2008, 10:15 »
well its quite straight forward once you start. the hardest bit is running it from the engine to the inside of the car,
i ran my lead down the side of the enigine and then through inside of the door (near where the plugs are for your elec windows)
it is very easy to do, especially if you have a forge dv as it has an extension on it. i wired all my wires together and put them on my light switch (grey lead behind light switch) it was going dark so i just did this as a tempory connection,  :smiley:
GTI MK5
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 20 March 2008, 10:19 »
so come on then, what boost are you peaking at with your remap?
Offline joesgti
« Reply #4 on: 20 March 2008, 10:23 »
im not sure, i think its about 1.2bar!! its about 17psi on full throttle. is this about right?? :huh:
GTI MK5
Offline joesgti
« Reply #5 on: 20 March 2008, 10:24 »
its actually 1.172 bar. is this good or not?? :huh:
GTI MK5
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 20 March 2008, 10:29 »
Sounds about right. You can get a bit more out of them but you'd really need a full exhaust before even thinking about tweaking it up.
Offline joesgti
« Reply #7 on: 20 March 2008, 10:31 »
so what would it be at standard?  :sad:
GTI MK5
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 20 March 2008, 10:34 »
something gay like 9psi, but it holds it to redline so you get the 'smooth power delivery' that they rave about. I prefer my torque curves (on F.I motors) to look like a big tit rather than a ski slope though!
Offline Manu_R32
« Reply #9 on: 20 March 2008, 11:20 »
Looking good joe  :wink: You need some petrol :P
OSIR Front Splitter - OSIR Rear Diffuser - RNS 510 - JL Audio Cleansweep - JL Audio 400/4 Amplifier - JL Audio ZR650 - Recaro Bucket Seats - 3.2 V6 of Pure Power!
