Author Topic: mk2 td  (Read 1705 times)
Offline hobbiniho
mk2 td
« on: 19 March 2008, 20:19 »
right i might have the chance to buy my brothers mk2 valver, that has been converted to a td  :rolleyes: basically my brother is in australia and has been for the past two years, he left his golf in the hands of one of his friends who has sinse, put several engines in it and now has a td engine now what i was wondering was how well do td engines cope with being run on sunflower oil??? he says that it will happily run on sunflower oil all day long, and its a hell of a lot cheaper than deisel  :laugh: :laugh:so is it worth my while getting it, should be able to get it pretty cheap and its got coilovers  :cool:
Offline Diamond Hell
  • Opinions я Us
Re: mk2 td
« Reply #1 on: 19 March 2008, 20:27 »
That age of TD motor should run OK on a part mix of veg oil.  You will need to keep the diesel content up, as it will thin the fuel.
Only thing is you may find it'll hasten the injector pump to it's demise - veg oil can be a bit aggressive on the seals.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: mk2 td
« Reply #2 on: 19 March 2008, 20:31 »
ive got a pegeout td for my daily run around which runs on bio diesel. been using it for 18 months now only 80p litre. smells like fish and chips  :grin:
Offline jammac
Re: mk2 td
« Reply #3 on: 19 March 2008, 20:34 »
it would also run sweet on kerosene!
if you know where to get hold of some  :wink:
ITS A TRAP!
Offline DarnPB
  • Formerly Darnpistonbroke
Re: mk2 td
« Reply #4 on: 20 March 2008, 06:41 »
Kerosene is dry though and can damage the pumps and what have you. To use kerosene, you also need to add oil.
But be carefull with the smell. If PC Plod smells it, he'll have you for tax evasion.
Offline hobbiniho
Re: mk2 td
« Reply #5 on: 20 March 2008, 09:00 »
ok sop what sorty of a mix are we talking here a half deisel half vegatable oil??? or more deisel??, im just wondering because it will be really cheap to run if i run it on completely veg oil at like 40p per litre  :grin:
Offline Simeon
Re: mk2 td
« Reply #6 on: 20 March 2008, 18:15 »
If you want to run it on pure veg then you would have to install a fuel heater otherwise it will solidify in your pipes when it's cold outside. I've run peugeot and citroen diesels on 50/50 mix without problems, very cheap if you get used fat from your local takeaway... Re PC Plod - most won't care and are unlikely to stop you anyway as you can buy biodiesel as already pointed out which smells the same. If you want to be 100% legal then you need to register as a biodiesel producer and pay tax on the amount of oil you use each month. Note - you can't do this if you are using new unused veg oil.
Offline hobbiniho
Re: mk2 td
« Reply #7 on: 20 March 2008, 18:50 »
i was planning on using new unused veg oil, am no wantin my car to smell like a chippy  :grin:
Offline Mew
Re: mk2 td
« Reply #8 on: 20 March 2008, 23:55 »
I'm sure there is an amount of miles you can do before you need to start paying a duty on it, and i'm pretty sure its well over 10k.
Offline Chantuz
  • MissMk2Golf
Re: mk2 td
« Reply #9 on: 21 March 2008, 11:15 »
Where sells bio diesel?? Something I wanna look into in the future but nowhere around me sells it
