Author Topic: Fogs eat fuses!  (Read 1916 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
Fogs eat fuses!
« on: 18 March 2008, 17:17 »
My front fogs on my 91 Digi kill every fuse I put in there! They kill the 10's and 15's as soon as I turn the fogs on, 20's last about 5 seconds and 30's start smoking before the fog lights cut out..... any ideas?
Offline hobbiniho
Re: Fogs eat fuses!
« Reply #1 on: 18 March 2008, 17:28 »
they muct be shorting out somewhere check all the connections and wires to make sure there not broken
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Fogs eat fuses!
« Reply #2 on: 18 March 2008, 17:33 »
ok well we all know we have fuses for a reason lol! yeh dont use them until you have found out whats going on. get yourself a voltmeter and work back from the bulbs to the switch in the car. do you know about continuety testing?
Offline JimR
Re: Fogs eat fuses!
« Reply #3 on: 18 March 2008, 17:37 »
Haha, i like the 'just use a bigger fuse till it doesn't burst' theory :D
As others have said, the live is shorting somewhere, trace all wires looking for obvious breaks from light to switch, then get continuity testing.
Mk2 GTi.
Offline Diamond Hell
  • Opinions я Us
Re: Fogs eat fuses!
« Reply #4 on: 18 March 2008, 17:53 »
Could be worse - I read the title of this topic as 'frogs eat fuses'.
Now that could be a right pain!
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Fogs eat fuses!
« Reply #5 on: 18 March 2008, 18:08 »
Dont know about continuety testing.....how do I go about it?
  • Opinions я Us
Re: Fogs eat fuses!
« Reply #6 on: 18 March 2008, 23:32 »
Get a multimeter, set it to monitor continuity and touch either end of the wire.  If it alarms there's continuity, if it's silent then the stretch of wire you're checking has a short in it somewhere.
Offline dubslug
Re: Fogs eat fuses!
« Reply #7 on: 22 March 2008, 12:38 »
mine was caused by bad earth at bulb end, remoed it all cleaned it up and they have been ok since
1992 pearl grey 8v
Offline Khare
  • The bear that khares
Re: Fogs eat fuses!
« Reply #8 on: 22 March 2008, 14:13 »
i got this kind of problem with my front washer. everytime i use it the fuse blows. must be a short circuit in the sterring column
Offline golf8v
Re: Fogs eat fuses!
« Reply #9 on: 23 March 2008, 13:12 »
i had this on mine it was faulty bulb try unplugin front fogs then put fuse in and try if it dont blow problem is in one fog light, if it does blow problem in loom
