Author Topic: Dashboard lights  (Read 1308 times)
Offline dannythomas752
Dashboard lights
« on: 18 March 2008, 13:15 »
Hi,
Recently my red dashboard light has been coming on, it is the one underneath the picture of the battery, does anyone have any information on what this means, I have looked in the haynes manual and it says it indicates something to do with the alternator.
It mainly happens when its raining does this mean the alternator needs replacing or maybe the battery, the car starts fine everytime
Any help would be appreciated
Thanks
Offline Mr Blue
Re: Dashboard lights
« Reply #1 on: 18 March 2008, 13:33 »
To me that sounds like a worn/loose alternator belt.
« Reply #2 on: 18 March 2008, 13:36 »
I have replaced the alternator belt, but it may not be tight enough, it does squeal in the wet so maybe thats what it is?
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #3 on: 18 March 2008, 13:38 »
get a voltmeter and check the voltage on the battery whilst the engine is running. then carefully wiggle the positive connection on the alternator and see if the voltage changes. if so then you'll have to repair whats a fault. maybe the alternator or the wiring loom
Offline russ-vdub
« Reply #4 on: 18 March 2008, 13:39 »
if it squeals then yeh you need to tighten the belt, and all corresponding bolts that allow adjustment of the alternator :)
« Reply #5 on: 18 March 2008, 13:41 »
Cheers gents,
I'll get it looked at asap, looking a bit of a fool everytime it rains and my belt starts squealing like a pig in a hillbilly film
 :grin:
Offline russ-vdub
« Reply #6 on: 18 March 2008, 16:12 »
yeh my belt went the other week, does make you feel like a right pikey hey!? funny to see the look on ppls faces tho
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #7 on: 18 March 2008, 23:40 »
Before re-tensioning the belt, or should I say, whilst re-tensioning the belt, remove it completely and inspect it for stationary wear. ie, a section worn away through constant slipping. If worn, launch it and fit a new one.
Offline cняis
« Reply #8 on: 18 March 2008, 23:46 »
it would be worthwhile removing the belt and taking some emery tape (or sand paper!) to the pulleys and get the shine off the grooves as this doesnt help!
« Reply #9 on: 25 March 2008, 17:13 »
I always set the tension to 5mm deflection at the longesty part.  You have to re-check every now & again after fitting a new belt since they stretch a bit!
